Support elasticity problem
Message 1 of 12
I have model consists of 270 723 nodes and 1786 panels (zero bars). I have some instabilities, however local support informed me that's normal.
At first I had modelled linear supports as pinned (fixed in Ux, Uy and Uz). Now I have changed Uz from fixed to elastic with kz=80kN/m (like for medium sand). Unfortunatelly at the end of calculations error no 100 occurs.
I tried to re-mesh last story (not helped). I was also trying to use Rafał program for round-up coords, unforunately during whole night progress of nodes (!) was equal to 10%, therefore I've must resign.
What shall I do? What are my options?
Replies (11)
Message 2 of 12
Artur.Kosakowski
Autodesk Support
Autodesk Support
Was the instability reported for this model?
What was the reason for doing this? Do you suspect that the instability is related to this story?
Artur Kosakowski
Message 3 of 12
Artur, what do you mean reported? I have spoken with polish helpdesk (Robobat), and at the end they said to me that some instabilities shall be expected and it's normal... Nonetheless the value of displacements are rather acceptable, so because of any other options within Robot I have accepted results gained.
Regarding second question - re-mesh is not at all connected with instability. Model is well meshed. I got that appreciation that error no100 may be connected with meshing, therefore I have tried to re-mesh area, where any changes have been done.
Message 4 of 12
Artur.Kosakowski
Autodesk Support
Autodesk Support
Was the instability reported when you calculated model with pinned (not elastic) supports?
Try to create a new load case and define a small load in the node where the instability was reported for d.o.f it was reported (UX displacement -> FX force ; RX rotation -> MX moment etc.) and check the displacements and rotations in this node.
Make a copy of the file and open it in the repair mode.
Artur Kosakowski
Message 5 of 12
The instability occurs even if supports are pinned and it listed in warnings. It stands: The instability (3 type) in the UX direction in the node 72576.
For the needs of your task, I have prepared a smaller model (only one floor - the instability above was also from that model), due to time of calculations. Before I had added new forces as you recommended I made a printscreen (visible in attachments) of nodal displacements.
Then I deleted all of the loads and leave only DLL as load type. I added a small force to the exact node (72576) equals to Fx=10kN and done calculations one more time. This time instability was found in node 9744. Please see attached print screen of those two nodes.
I will do it later on, as I need to work in model by the time. Right now I have answered to some other issues.
BR.
Message 6 of 12
Artur.Kosakowski
Autodesk Support
Autodesk Support
For the needs of your task, I have prepared a smaller model (only one floor - the instability above was also from that model). Then I deleted all of the loads and leave only DLL as load type. I added a small force to the exact node (72576) equals to Fx=10kN and done calculations one more time. This time instability was found in node 9744. Please see attached print screen of those two nodes.
What are the displacements and rotations when you apply FX=1kN in node 9744 for this 'reduced' model?
Artur Kosakowski
Message 7 of 12
Answer in attached print screen. Now, after loading node 9744, the instability occured in node 72097.
Message 8 of 12
Artur.Kosakowski
Autodesk Support
Autodesk Support
This indeed suggests that the instability may be just caused by large difference of values of elements of the stiffness matrix. Are you able to calculate this smaller mode with Skyline solver?
Artur Kosakowski
Message 9 of 12
Artur,
I am using normal types of elements - slabs, walls etc. None of them with extraordinary dimensions...
I have changed solver into Skyline, see attached print screen.
Message 10 of 12
Artur.Kosakowski
Autodesk Support
Autodesk Support
So we can't see if it also reports the instability.
The difference may be due to other reasons e.g. RLink elements user for linear releases, defining them for all edges of a panel or very small surface element generated during meshing and may be reported for correctly defined models.
Artur Kosakowski
Message 11 of 12
Artur, how can I be sure that results are correct? 🙂 How shall I model linear releases?
By the end of day I will also try to run model with kz.
Message 12 of 12
Artur.Kosakowski
Autodesk Support
Autodesk Support
The support seems to have nothing to do with the instability  as you made the corresponding test: 'The instability occurs even if supports are pinned'.
If you have them defined for all edges of a slab you may add RZ support in any of its mesh nodes.
This is what we were trying to verify by checking the results for any abnormal values:
'Nonetheless the value of displacements are rather acceptable, so because of any other options within Robot I have accepted results gained.'
and applying test loads in the locations of the reported instabilities which if anything there is wrong should give very large displacements or rotations.
Artur Kosakowski
