Cut under angle problem
I was using Structural elements/openings for the needs of perpendicular to main axis openings in slabs. However I cannot use that tool when it comes to the cut under some angle. I was trying to use Polyline - Contour or Rectangle by three points, but I never get opening in the panel.
Any thoughts what I am doing wrong?
For better understanding please see attached print screens.
BR
Artur.Kosakowski
Autodesk Support
Autodesk Support
What about replacing a slab with two smaller panels?
Artur Kosakowski
Finally I managed to prepare cut, somehow. It's strange how capricious Robot is. Nonetheless thank you for help.
