Support Condition for subframe analysis
efyjw7
efyjw7
Hi robot experts here, is putting the fixed support at the red circle correct for the subframe analysis if i have a structure like this?
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @efyjw7
Default connection type between members for Frame structure type is fixed. You do not need to define support in that node if supported column is a part of this substructure.
Krzysztof Wasik
