Hi all,
When I do model generation for a building with dynamic analysis procedure,some support appears in the upper structure.
Refer to clouded area in the attached picture .
If this support is a real structural support or just a presentation for something ?
Regards;
Solved by Artur.Kosakowski. Go to Solution.
Dear Rafal
Linear supports?
yes
Open file in repair mode.
it does not help
If it does not help,please send us model.
kindly find attached model
Regards
The vertical support is automatically generated in the master node of rigid links that model diaphragm for the panel. If it wasn't there the calculation node generated in its center would not be restrained against vertical displacements.
