Structural Elements disappearing after saving and opening large models
joe.akiki45GWY
joe.akiki45GWY
I'm having a problem after saving large models. When i open those models , a lot of structural elements disappeared as you can see in this exemple. this isn't the first time it happens .  Has anyone had this problem before ?
The only solution i found is to open the model in repair mode. This works a lot of times, but i find it risky anyway since you may lose some of the data sometimes . ( supports …) .
Do you know what is causing this problem and how can i avoid it .
Rafacascudo
Try geometry/stories/filter stories
Rafael Medeiros
joe.akiki45GWY
Stories are not yet defined in this project.
I dont think this issue is related to stories because i have it on large models in which stories are defined and on others where stories aren't defined yet.
the problem occurs after saving a model with a heavy geometry, closing and then opening it.
Rafacascudo
Send the model. Zip it before attaching
Rafael Medeiros
joe.akiki45GWY
Ok , i just did another simple exemple from scratch , with a lot of elements like the other models i have.
As you can see , the same problem occured. Kindly find attached the model.
Thank you.
Romanich
Hi @joe.akiki45GWY , welcome to the club:
https://forums.autodesk.com/t5/robot-structural-analysis-forum/disappearing-inactive-bars-and-panels...
Roman Zhelezniak, P.Eng.
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
joe.akiki45GWY
Hi Romanich, thank you for you reply.
So the problem is still unsolved by Autodesk ?
We don't know what's causing it besides that it happens on big models ?  So We don't know either how to avoid it.
The only working solution for now is opening in repair mode ? Knowing that this solution is risky as others have mentioned and we can lose some elements and loads .
Thank you.
