Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Stress in Section Module
3 REPLIES 3
t.sautierr
332 Views, 3 Replies
Artur, Rafal,
I currently performing a (simple) study on a complex section (hot rolled jumbo profile encased in a concrete mega column). For now, I just want to be able to have a distribution of constraint with the hypothesis of continuouns linear strain -> ok if I am in compression everywhere but if I put a sole bending moment, RSA is calculating traction stresses in the concrete, is there a way to integrate to disregard traction in the concrete?
Is there also a way to accelerate graphical display, it just so long .....
Thx.
File attached
3 REPLIES 3
Hi Thomas,
You cannot disregard tension in concrete in the Stress Analysis in Robot but as far as I know thjis is what is done in Autodesk Structural Bridge Design
Artur Kosakowski
Are you advising me to purchase  Autodesk Structural Bridge Design 🙂
So no solution even if defining a new material with non linear properties ? I assume this because the stress analysis is performed on the basis of rdm formula ? no further calculation except the geometrical properties of the defined section?
The point is that in Robot you cannot define such material.
Artur Kosakowski
Technology Administrators
