strength reduction factor modification
jneves1990
jneves1990
Hello fellow community!
I there a way to change the strength reduction factor (fi) for the ACI design?
I've been warned that due to the seismic combinations these strength reduction factors change.
Thanks in advance!
João Neves
Rafal.Gaweda
Autodesk Support
Autodesk Support
Not possible.
Rafal Gaweda
jneves1990
@Rafal.Gaweda wrote:
Not possible.
Thank you Rafal.
Can't you put an algorythm that regonizes seismic combinations and thus change the reduction factor into the next version?
Rafal.Gaweda
Autodesk Support
Autodesk Support
Can you post here code table with reductions factors for seismic?
Rafal Gaweda
jneves1990
Dear Rafal,
The Appendix C of ACI 318M-08 is a whole chapter regarding alternative load and strength reduction factors.
As it is shown in the pictures attached, the reduction factor for some combinations is different from the usual in which this reduction factor goes from 0,65 to 0,9.
