Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Strange values in Reactions table
3 REPLIES 3
stroxy
434 Views, 3 Replies
I am noticing some strange values in my Reactions table as follows
  • In static load cases where only vertical loads are applied, I am finding reactions in the horizontal direction
  • There is quite a big discrepancy between sum of applied loads and sum of reactions
I have attached some snapshots of the Loads and Reactions Table.
The building has been modelled on piles with linear springs attached over the length of the pile.  I notice there are horizontal reactions in the springs decreasing towards the base of the pile.
Could it be the deflection of the piles under static loads is causing these horizontal reactions in the springs?
is that why the forces and reactions are not adding up?
3 REPLIES 3
Rafal.Gaweda
in reply to: stroxy
Tower Model?
Rafal Gaweda
stroxy
in reply to: Rafal.Gaweda
Yes, the same model i sent you
Rafal.Gaweda
in reply to: stroxy
OK, we will check model
Rafal Gaweda
Technology Administrators
