Strange bug related to deleting elements
MartinTrs
MartinTrs
Hi!
I'm using RSA 2018.02 and I have encountered a strange problem a few times now. When selecting one element and deleting it, a few other unselected elements may also be deleted. I tried to illustrate the problem in the following screencast:
There are very few elements that act like this and I have no idea why this is happening. So extra caution should be taken when modifying your model by deleting elements!
Best regards,
Martin
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @MartinTrs
Could you attach this model?
Artur Kosakowski
MartinTrs
Hi @Artur.Kosakowski
I sent it through private message.
Opening the model in repair mode fixes the issue but the problem is that the user might not always notice that the problem exists. Since it has happened many times, I decided to write about it.
Best regards,
Martin
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @MartinTrs
Thank you for the file. I have asked the development team to try to determine what corrupts the file to avoid such situation in the future.
Artur Kosakowski
