Seismic weight calculation error
mgaafar
mgaafar
    attached a multi-story building. I noticed that the self-weight used in the seismic calculation is different to what the load case of self-weight and I don't know why.
Self-weight Case Total vertical load         = 95,549 kN
Effective Seismic Weight = 8,244,740 kG = 82,447 kN
Any thought why this is happening?
mgaafar
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @mgaafar
The weight of curtain walls is disregarded in the equivalent lateral force method. You can either convert them to meshed panels or define self weight for curtain wall (cladding) panels in a separate load case and convert it to masses.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
mgaafar
May I Suggest that a warning message that show up stating that the cladding weight is not accounted for when calculating the effective seismic weight so users are aware of this.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @mgaafar
I'd rather have it included. I have already asked the development team if this could be done.
Artur Kosakowski
mgaafar
Artur, I agree as well that it should be included in the Selfweight same as all other elements, but if not then at least a warning message should be introduced to warn the user.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @mgaafar
At this stage we have to wait for the development team decision on this matter. I'll update this topic when I have any new information.
Artur Kosakowski
