Hi @umut.akparlar
The modal frequencies for your model are pretty high. The first mode frequency in modal analysis is 21.71 Hz.
You need to set higher "Frequency limit" in the "Modal analysis parameters" for Footfall analysis. Then you will get results for the Footfall case.
I'm not sure if it is intentional, but you set "Disregard density" (self-weight) for modal analysis case, but you didn't do it for Footfall. Remember that Footfall runs its own modal analysis with parameters as above.
Waldemar Okapa
Sr Product Owner
