- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi, another question on steel design to Australian code;
In all of the steel beams in the Australian steel database, I cannot find a value displayed for Iw (warping constant).
When I perform steel design check, the results do not display Iw anywhere.
Background:
In accordance with 5.6.1.1 of the code, alpha s is calculated using the reference buckling moment (Mo). To obtain Mo, you need Iw, unless you conservatively choose Iw to be equal to zero.
When I cross check Robot output with my hand calculation (which has the correct Iw), I get the same answer for alpha s and also Mo and Mb. If I use zero for Iw, I get different results to Robot. This tells me Robot is using the correct Iw, but I just can't see where it is!
Question:
- How is alpha s calculated in Robot? Does it use Iw, or does it assume Iw = zero?
- If robot is using Iw correctly (seems it does), then why can't I see what Iw is?
- Why does Robot not consider Mo, Mb, alpha s for minor axis bending? i.e. Why does Robot not perform lateral buckling check for minor axis bending.
Thanks again,
Tony
