Steel design API, manual verification
Is it possible to use Manual verification via API in RSA 2015?
I used search and found old thread
http://forums.autodesk.com/t5/robot-structural-analysis/manual-calculations-for-steel-design-using-ap...
According to this thread "Manual verification" is not possible via API. I was just wondering if it is possible in newer versios of RSA.
I use EN 1993-1-1 design code (E32 in API). The problem is that utilization ratios for strength of cross-section are often missleading. For example, if cross-section has internal forces N + My the utilization ratio is 0,81. When I add Mz, the ratio will decrease to value 0,62. Please, see attachment.
This is obviously unrealistic result. The real utilization ratio for case N+My+Mz is somewhere between 0,81 and 1.
I would like to create macro that calculates real utilization ratios by increasing internal forces until maximum utilization ratio is 1,00. The reciprocal of load factor would be linearized utilization ratio, which would tell the real capacity of member. If this "linearised utilization ratio" would be 0,50, the member strength would be sufficient if I multiply all internal forces by 2.
It is possible to write internal forces to governing case via API, but I have not figured out how to calculate new utilization ratio with internal forces specified via API.
Rafal.Gaweda
Autodesk Support
Autodesk Support
Unfortunately it is not possible by API.
Rafal Gaweda
Thanks for answer 🙂
Do you have some other solution in mind to this utilization ratio problem? I would like to get real ratios for members somehow.
It would be nice if this manual verification possibility would be added to API to next Service pack of RSAP. 🙂
Rafal.Gaweda
Autodesk Support
Autodesk Support
create dymmy case
assign loads to it
calculate structure
run design
Not planned.
Rafal Gaweda
