Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board.
Steel connection design - Pinned column BP, unable to offset column&anchors
haroon.ashraf
haroon.ashraf
Hi ALl
Trying to do a simple design check on a pinned column base with an axial force and shear force in X and Y. Probably an easy one but I seem unable to offset the column and anchors relative to the base plate. The option remains grayed out and I can't figure out how to do it - I've looked through the manual and done a general search through the forums and interwebs.
Design intent is shown in screen-grab below
Model is attached with my attempt - anyone spot what I am missing?
Simau
@haroon.ashraf
Not possible to offset the column.
You can do it with finite element;
In your exemple keep in mind that -285 kN is a compression effort
M. Agayr
haroon.ashraf
@Simau Thanks for the swift response. Noted on the forced, will switch so its a tension force 🙂
Seems disappointing unable to model connections such as these as they are fairly common, this is a gable end column, whilst the other columns in the building have more 'regular' spacing/arrangement of column and anchors.
EDIT: it seems possible to offset using the fixed base plate connection..I will use that and not enter any moments 🙂
haroon.ashraf
Actually still not possible to offset column using fixed column baseplate module... at least with EC3...
