STABILITY ISSUES IN TRUSS MEMBER
13 REPLIES 13
Message 1 of 14
931 Views, 13 Replies
KINDLY HELP ON THIS. Capture.JPGTHANKS
13 REPLIES 13
Message 2 of 14
DennisVDijk
[1] Truss members only take axial forces;
[2] Your member is under tension, so no buckling check is needed and only the section check is aplied.
See screen below:
Knipsel.PNGhope this will help you 🙂
Kind regards,
A&I│KWANT
adviseurs & ingenieurs
Dennis van Dijk
Structural engineer
www.ibkwant.nl
Message 3 of 14
in reply to: DennisVDijk
However, I think there is a check for tension resistance. How can we check for tension members stability in robot? Does it mean Robot lacks this???
Message 4 of 14
DennisVDijk
Members under tension have no stabily issues. Buckling is a compression fail meganism.
Kind regards,
A&I│KWANT
Dennis van Dijk
Structural engineer
www.ibkwant.nl
Message 5 of 14
solved, thanks so much for this.
Message 6 of 14
HI
Message 7 of 14
Romanich
Not possible to change.This is a sign convention for bar elements: positive - compression, negative - tension.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Message 8 of 14
in reply to: Romanich
KINDLY CHECK THE TOP CHORD, WHY IS THERE COMPRESSION AND TENSION?
Message 9 of 14
Artur.Kosakowski
Hi @Anonymous
Try to select only the top chord and open it in a new window and then display the axial force diagram. It is not clear what values are for what element on the picture you attached.
Artur Kosakowski
Message 10 of 14
in reply to: Artur.Kosakowski
Tags (1)
Message 11 of 14
Artur.Kosakowski
Hi @Anonymous
Could you attach both the model and your hand calculations (indicate the part for the top chord)?
Artur Kosakowski
Message 12 of 14
DennisVDijk
Your support on ax 7 must be free in x direction, only support vertical. If both support on ax 1 and 7 are fixed horizontaly, tension force will built in the top cord due to bending.
Kind regards,
A&I│KWANT
Dennis van Dijk
Structural engineer
www.ibkwant.nl
Message 13 of 14
Thanks man, you are good.
Message 14 of 14
jayvans
Change the supports to pinned and roller
Technology Administrators
