Soil Reactions are 50% of applied load
keith483GL
Message 1 of 8
keith483GL
I am attempting to model an uncommon situation with a ground bearing slab. To get to grips with how ROBOT models soil support I have a set up a simple model to test it is working as I wish.
I have encountered a problem in that my applied UDL panel load of 30kN/m^2 is resulting in a soil reaction of 15kN/m^2.
I have checked the reactions table. It is telling me that the values add up to 180kN, whereas they should add up to 360kN. The slab area is 2m x 6m, so (2 * 6 * 30) = 360kN.
Does anyone know why this is and how to resolve it?
Keith
Replies (7)
Message 2 of 8
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @keith483GL
Could you  share your model for verification?
Krzysztof Wasik
Message 3 of 8
keith483GL
Hi Krzysztof,
I have tried to drag and drop the model file, but it is coming up with an error.
Am I doing something wrong?
Keith
Message 4 of 8
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @keith483GL
Save model as RTD without results and zip before sharing.
Krzysztof Wasik
Message 5 of 8
keith483GL
Hi @Krzysztof_Wasik
I hope this works.
Message 6 of 8
HoshangMustafa
Message 7 of 8
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @keith483GL
You have duplicated supports
1- support is defined in thicknes definition (elastic soil parameters)
2.- support is defined as planar support
They should not be used together. Remove planar supports . Then slab will be supported by elastic soil defined with slab thickness and results will be as expected.
Krzysztof Wasik
Message 8 of 8
keith483GL
That's sorted it @Krzysztof_Wasik
Thanks for your help and assistance.
