soil load calcculator
memoalcr
memoalcr
When using the soil load calculator (loads > special loads > soil pressure...)
The input parameters for my own soil do calculate the correct coefficients ka k0 kp
However if I compare the applied pressure to the panel vs. a manual calculation, the computed calculation is more than double
Where is the mistake?
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @memoalcr
Soil load is applied as contour load defined in 3 points. Load description presents pressure value for points deined in load properties. Probably presented value (-4231) is assigned to point below your structure base level.
You can check it by displaying load properties (highlight load symbol then click right mouse button and edit load properties.).  You can also zip and share Robot model for verification.
I suggest  comparing results  of soil calculatior with pressure defined manually (according to manual calculations). Probably results will be the same.
Krzysztof Wasik
memoalcr
Thank you. What confused my was the -4232 value, but looks like the applied loads are OK
