Good afternoon,
I am trying to check SLS deflection and cracking on the simple model ( floor slab ) as attached, however RSA returns staus message of 'required types are not ascribed to SLS combinations' This is under SLS combination '5'
I have tried few things but to no avail. Similiarly, cannot get cracked values to be shown. Model attached
As always.... any tips greatfully received!
Cheers
Lee
Solved by Artur.Kosakowski. Go to Solution.
Solved by saclovitzky. Go to Solution.
Please check:
http://forums.autodesk.com/t5/robot-structural-analysis/sizing-slab/m-p/3280315
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
