SLS Check (Deflection and Crack)
TienDat.NGUYEN.Engineer
Message 1 of 9
Can anyone know how module Robot in panel calculation can calculate the reinforcement only ? I use the Panel module but the result for crack and deflection is nothing.
I don't know is there any thing missing in my calculation.
In this case only the flexural reinforcement is shown:
But the crack and deflection is none ?
Replies (8)
Message 2 of 9
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @TienDat.NGUYEN.Engineer
Have you defined SLS combinations? Deflections and Cracks are calculated when SLS combinations are selected for verification. Share zipped RTD file for verification.
Krzysztof Wasik
Message 3 of 9
Dear @Krzysztof_Wasik ,
Yes I have defined the SLS combination (201), and both ULS (101) & SLS (201) is defined in the calculation of panel as shown in below:
But only the value in ULS show the results, for SLS it will appear this error message and the value is zero for all.
I also attach the model Robot, if possible could you please help me to check this point, thank you in advance for your help.
Message 4 of 9
Romanich
Hi @TienDat.NGUYEN.Engineer ,
You should assign correct SLS type:
Or in the table:
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Message 5 of 9
Dear @Romanich ,
I have tried to change to SLS-Quasi permanent but the result is still zero the same as below.
Did you check on the model on your side ? Does it have the result ? Thanks in advance
Message 6 of 9
Romanich
Maybe the reason is that you have a span 1.1 m and 200 mm slab thickness. For example, I have applied supports to have the bigger span:
Roman Zhelezniak
Message 7 of 9
Dear @Romanich ,
I think so, I try like you proposed and they have the result but not same as you. And for crack width still has no result
Could you please upload the modified model ? I can study on this one.
Message 8 of 9
Romanich
Model attached (Robot 2022)
Roman Zhelezniak
Message 9 of 9
Krzysztof_Wasik
Autodesk Support
Autodesk Support
You have too small loads to obtain cracks for defined slab geometry and loads. Cracks appears when you increase loads in your model. I have increasd live loads to 150 kN/m2. Then X- cracks are 0.2 mm.
Krzysztof Wasik
