Slight Mismatch Between Values in Robot and Excel VBA
WALIDGIO
WALIDGIO
Hello everyone,
I've encountered a slight discrepancy between the values retrieved using Excel VBA from Robot Structural and the values shown directly in the Robot application.
In the image attached, you can see that the Max UX and Min UX values retrieved from Robot and displayed in Excel differ by about 0.01. The values in the Robot application (highlighted in red ) and those in the Excel sheet do not match exactly.
knowing that I'm using the same comb number in the VBA code.
Has anyone else encountered this issue? Is there a known reason for this slight difference? Also, are there any solutions or workarounds to ensure that the values match exactly when retrieved via Excel VBA?
Thank you in advance for your help!
WALIDGIO
@Stephane.kapetanovic
sorry to bother 🙂 but can you help.
If your request requires verification of a hard-coded program or involves modification of the software architecture, you should direct your questions to Autodesk personnel.
Stéphane Kapetanovic
don't forget to accept the solution and leave a < like !
WALIDGIO
thank you stephane,
maybe @okapawal can check this with us
