Mismatch in levels for same Z ordinate in Force in point
sukusPNXGV
sukusPNXGV
I applied force in model using force in point option. Later I moved this force by editing its coordinates in Load Properties. Even when I gave same Z axis ordinate, the force does not seem to be applied at this height. I have applied two force in point loads with same Z ordinate just for reference, these two appear at different levels which is surprising.
Attaching the model. It's just a small model. I have edited coordinates of a lot of force in points in my actual model. And its showing "The load has not been distributed correctly - There are no objects or elements carrying the load overlap". How can I solve the problem?
Simau
Hi @sukusPNXGV
 The level is 4.15, not 4.
Go to Tools > Job Preferences > Units and Format and set decimals at 2
Model attached
M. Agayr
sukusPNXGV
Thanks, Simau.
