Slanted Cladding Surface & Uniformly Distributed Load Not Working?
I am trying to model a steel frame roof with timber infill joists.
To make things simple I just wanted to create a surface with no deadweight automatically associated to it and apply a load to the surface which would represent the dead / live / etc loads applied to the roof.
To use this I used the cladding surface tool.
I set the cladding surface to be one way spanning - simulating joists spanning between the steel frames.
However when I apply a uniform surface load in the Z direction to a slanted surface it doesn't appear to resolve the force as singly spanning - if at all.
Anyone experienced this or would know what I am doing wrong?
I am using Robot 2019, Windows 64bit
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
Make sure the claddings are flat.
You may use this tool to do so.
If it is not the case , please post your file.
Rafal Gaweda
