Slabs crack control
13 REPLIES 13
Message 1 of 14
marko.glavinic89
1344 Views, 13 Replies
Slabs crack control
I have a problem regarding crack control in RC slabs. I have created a SLS:QPR combination with aqequate load factors, and when i run the reinforcement calculation everything goes well. I get the required reinforcement area, aswell as deflections, but i cannot obtain crack width no matter what I do.
Can you help me, I attached the model with no results.
13 REPLIES 13
Message 2 of 14
in reply to: marko.glavinic89
Isn't there anyone who knows what may cause this problem? I am not able to get crack widths either which is odd since concrete always cracks.
Message 3 of 14
Rafal.Gaweda
It cracks, but only in one node so it is hard to display map.
This is 100cm slab with RC deflection of 2mm max
Rafal Gaweda
Message 4 of 14
in reply to: Rafal.Gaweda
I have a ground bearing slab that has no cracks. How do you explain that?
Message 5 of 14
Rafal.Gaweda
50 cm slab with RC delfection 3,7mm....
Rafal Gaweda
Message 6 of 14
Are you suggesting that the deflection is so small that there should be no cracks?
Message 7 of 14
Rafal.Gaweda
seems so.
Rafal Gaweda
Message 8 of 14
I dropped the foundation elasticity quite a bit and got a much greater deflection but there is still no cracks. There is no way this is correct.
Message 9 of 14
Rafal.Gaweda
If wrong - please send me your hand calcs to compare
Rafal Gaweda
Message 10 of 14
Rafal.Gaweda
From "tomorrow" webinar:
Rafal Gaweda
Message 11 of 14
Thank you for that information. Looks more believable. This method doesn't take into account reinforcement or changes in the stiffness caused by cracking does it?
Message 12 of 14
Rafal.Gaweda
If slab is situated on the soil (in Robot on elastic ground), it will not deflect deeper (even considering cracks and reinforcement) than calculated in FEM model because soil prevents this.
Rafal Gaweda
Message 13 of 14
Bending causes deflection and since concrete can't take tensile strain, we use reinforcement. We can diminish the crack width using more reinforcement. It's not a question of deflection getting deeper. Also this is only true when the deflection is downwards which it always isn't.
Message 14 of 14
Rafal.Gaweda
