slab shell panel floor
Message 1 of 9
Can someone briefly explain how floors, slabs, shells, and panels are defined different in RSA?
Replies (8)
Message 2 of 9
Mohammed_Ata
More clarification, PLZ.?
Message 3 of 9
If I define a slab as a floor, it wont run the calculations. If I define it as a shell, it will.
Message 4 of 9
Mohammed_Ata
1- It is a structure object: For design
2- It is a panel calculation model: For analysis
Message 5 of 9
Slab reinforcement appears but drawings don't get generated.
I'm trying to display the drawings I reviewed forums regarding this issue and nothing is working.
1- tried freezing then unfreezing the reinforcement, didn't work
2- tried changing calculation model from deck slab to shell, didn't work.
Please find attached file and pictures
Message 6 of 9
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Did you press the indicated button to generate the drawing?
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
Message 7 of 9
Yes, I pressed the "calculate" button, then checked the "generate drawings" tickbox. An empty drawing page opens up. No errors
Message 8 of 9
Message 9 of 9
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Check if you have the correct slab drawing template set before generating the drawing:
Artur Kosakowski
