Slab self weight doesn't transfer to columns
Hello!
I'm having problem with self weight transfer to columns. I haven't had this problem before but it seems that slab self weight doesn't transfer to columns. I have attached the file.
Best Regards
Rasmus
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @Anonymous
I have calculated your model and axial forces distribution in columns looks ok. There is expected axial force "jump" at slab levels.
You have defined too many releases, resulting in Instability type 1 but it has no influence on axial forces in columns which seem to be correct.
Please describe issue with more details.
Krzysztof Wasik
Hi!
Thank you for answering so quickly! Reaction from dead load (self weight) at the red circle should be around 1500kN if i calculate it manually.
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @Anonymous
Remove elastic ground coefficient from thickness 27 and 28. Reaction changes to 1400 kN
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Krzysztof Wasik
Thank you very much!
