- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi all,
I have several questions about punching shear calculation results in Robot.
1. Is it possible to grab punching reinforcement results in excel using some API, Macro or results connect? I need area of reinf., rod diameter and quantity in different distances from the column edge.
2. From which point L1 and L2 are measured? In help it is wrote that "L1, L2 - Reinforcement range from the member center in both perpendicular directions." In prinout calculation report there is a small drawing showing that L1 and L2 are distance from column edge, not from the center...
3. Reinforcement area (As) and stud quantity with rod diamter provided by robot is the total quantity of punching reinforcment that should be destributed on whole critical perimeter or it is only one "side" reinforcement or both sides? See attached pictures below.
