slab moment in robot
husamcivil
Message 1 of 8
husamcivil
When I analysis slab the moments are not equal to the hand calculation so what method will be good hand calculation or robot results and what can I do so that robot result will equal hand result
Replies (7)
Message 2 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @husamcivil
Could you attach both the Robot model and your hand calculations?
Artur Kosakowski
Message 3 of 8
husamcivil
Message 4 of 8
husamcivil
Hi all
there is a difference between hand calculation and robot result in slab moment
what is the problem ?
Is robot result is O.K or hand calculation
what procedure I can do it to make both hand and robot result will be equal
 note: I attach both  robot  and hand file  calculation example
thank you all
Message 5 of 8
mustafahesenow
Mustafa Hesenow
Senior Structural Design Engineer/MZP
LinkedIn
Message 6 of 8
mustafahesenow
Mustafa Hesenow
LinkedIn
Message 7 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @mustafahesenow
Thank you very much for the time you committed to investigate the model.
Artur Kosakowski
Message 8 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @husamcivil
I just wanted to check if you found the suggestions posted by @mustafahesenow helpful. If yes, would you mind to mark his post as the solution? Thank you.
Artur Kosakowski
