Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
slab mesh ignore column node !
8 REPLIES 8
Message 1 of 9
me1205377
938 Views, 8 Replies
Greetings
after i calculated the model and checked deflection it became clear that some columns weren't  recognized as the support for slab above
i checked the column node coordinates and it is on the same plane as my slab , i deleted the mesh and re meshed it again but the problem persist
i selected the slab and from object inspector  tab i updated contour definition and then re meshed it again but the problem remain
moustafa elgaar
8 REPLIES 8
Message 2 of 9
Hi @me1205377
Try to use the detailed correction option with the correction to the horizontal plane with given Z coordinate and then mesh the panel again.
Artur Kosakowski
Message 3 of 9
thank you for the fast reply  🙂
i  did exactly the following  so please correct me if that was not what you advised me to do
selected the slab >> Detailed structure correction >> selected "to plane"  >> defined  3 points having the same Z coordinates on my slab " i used other columns node which was connected to the slab successfully before and checked their coordinates " >> set the range to be "current selection" >> apply
deleted the mesh and re meshed again but didn't solve the problem
moustafa elgaar
Message 4 of 9
mustafahesenow
in reply to: me1205377
Hi @me1205377
All what you need to correct is the columns node at this level .then re mesh the slab.
Mustafa Hesenow
Senior Structural Design Engineer/MZP
LinkedIn
Message 5 of 9
me1205377
in reply to: mustafahesenow
the node is exactly in correct elevation , other columns with same node coordinate got meshed correctly but no this one
moustafa elgaar
Message 6 of 9
mustafahesenow
Hi @me1205377
Send me the model Please.
Mustafa Hesenow
LinkedIn
Message 7 of 9
me1205377
kindly take a look on column 931 and 1143
moustafa elgaar
Message 8 of 9
mustafahesenow
Hi @me1205377
Since the column Node is exactly at slab level .
You select the nearest node of the mesh to the column node then move it exactly to column node.
Then you select both of the 2 nodes and you go to edit then correct un check all options and put precision 0.005m then click apply .
The nodes will be merged in one node .
Make run to the model and everything will work well
Mustafa Hesenow
LinkedIn
Message 9 of 9
Hi @me1205377
The technique demonstrated during the 2nd Robot webinar Smiley Happy
Artur Kosakowski
