Slab deflection results for provided reinforcement when less than required
davidthompson6Q5UV
Message 1 of 1
davidthompson6Q5UV
I am trying to analyse an existing RC flat slab as part of a design check exercise. I need to generate deflection and crack patterns for the slab using actual reinforcement as built.
After inputting actual provided reinforcement information for a panel, running a calculation on the panel generates error messages stating that 'too little reinforcement' is provided in some areas (as was expected in the case of this slab).
As a result, the provided reinforcement cannot be 'verified'. Because of this, I appear to be unable to see FE results for deflection or cracking using the actual provided reinforcement (the option is greyed out).
So my question is: is there any way in which deflection and cracking results can be generated for cases when provided reinforcement is less than required?
Many thanks for any help that can be offered!
Replies (0)
