Simply Supported Slabs and Beams – One-Way vs Two-Way Behaviour in Robot
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am new to Autodesk Robot Structural Analysis and I am modelling a single-storey building with walls, columns, beams, and slabs. I want to model the slabs as simply supported and compare the results assuming one-way and two-way slab behaviour. I have tried:
Changing the Panel Calculation Model to the Simplified (trapezoidal/triangular) method for both one-way and two-way slabs
Applying linear releases along slab edges (I am still getting small moment peaks at the slab edges, and the slab behaviour does not clearly reflect the intended support conditions.)
Using orthotropic material properties to increase stiffness in one direction only.
Changing the slab model from Shell to Load Take-Down one-way and two-way (When using Load Take-Down, the beam results seem closest to what I expect for simply supported behaviour; however, in this case no slab results are available)
I also want to model the beams as simply supported, but end releases do not seem to fully remove continuity effects or moments at the supports.
Would appreciate some advice how to model this please. This is the model file for reference.
Thank you in advance for your help.
