Simple solution I hope, Unable to determine reinf for my RC beams
raziul_aliJW7PS
raziul_aliJW7PS
Its the first time im using ROBOT to determine the reinf in some RC beams. I just cannot seem to get the program to work. I just get errors and I don't understand what I need to do in order get ROBOT to provide the reinf.
Model and screenshot attached for reference.
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @raziul_aliJW7PS
You have used column section type to define beam
. Redefine beam sections using Beam section type.
You probably defined too big loads . You have defined load values in kN/mm. Please correct your loads also.
Krzysztof Wasik
raziul_aliJW7PS
I have tried making the adjustments you suggested, but I am still unable to see any reinforcement. I do get an error message, which I have attached here. When I try to look for the 'general tab' and the 'reinforcement pattern' dialog box, I cant seem to find that anywhere in Robot.
