- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm currently analysing silo for storing corn. The silo is made of S235 steel plates 3mm thick with reinforcing ribs 6mm thick, overall dimensions are 2300x2300x8700. On the attached picture you can find more model information. As you can see side plates are deformed about 200mm, that is quite a lot but having in mind that silo volume is big and steel plates are relatively thin, maybe that's ok . Just for check, we have made the identical model in Ansys and get the identical load distribution but deformation was about 57mm. Could you please clarify following:
1. Is hydrostatic load applied correctly?
2. What 7.85 in the load label [p hyd = (0.0, 7.85)] stands for?
3. Is it possible to display hydrostatic pressure values on the bottom of the silo or some specific elevation?
Thank you very much in advance.
Best regards
Tihomir
