shifted column on retaining wall
me1205377
Message 1 of 8
me1205377
Greetings,  please advice on the following case
i have a retaining wall that carry a column  starting from ground floor , the column is shifted 5 cm from the centre of the wall and i want to make this in my model.
 so is this is the best way to model it ?  or should i make the column start from the bottom of the retaining wall? is a one rigid link between 2 nodes is enough to mimic the real case or more rigid links are needed ?
Also regarding the design is it possible to design this retaining wall in robot
your suggestions are highly appreciated
moustafa elgaar
Replies (7)
Message 2 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @me1205377
IMHO the best way to model the offset is to use rigid links. Unless your retaining wall is just a wall of a building being under the ground level so that it boundary conditions are a foundation at its bottom and a slab at its top modelling it in a general FEM program will be tricky as you relay on the equilibrium of forces to secure the wall stability rather than supports.
Artur Kosakowski
Message 3 of 8
me1205377
the top slab is not resting on soil, it the ceiling of the basement behind the indicated retaining wall
i am sorry  i couldn't  understand the situation you described
i made the offset with one rigid link.  i added a node to the retaining wall top side and made it the master node, the slave node was the column bottom node , all degrees of freedom are locked is this enough ?
also regarding the design of such wall, is it possible in robot
moustafa elgaar
Message 4 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @me1205377
Could you attach the cross section through the wall so that I could better understand the situation?
Artur Kosakowski
Message 5 of 8
me1205377
moustafa elgaar
Message 6 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @me1205377
IMHO you can design this wall in RSA as it is more a basement wall rather than a retaining wall. For calculations of reinforcement I'd use RC Slab approach (for you have out of the plane bending) as explained during the 5th Robot webinar. I think that the definition of the rigid link as you described it is fine.
Artur Kosakowski
Message 7 of 8
me1205377
just for my info what is the difference between a basement wall and a retaining wall
for the :basement wall"  i will define it as a   panel not a wall with shell calculation model correct ?
moustafa elgaar
Message 8 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @me1205377
Correct.
Artur Kosakowski
