Shell polygonal tower
simas.lembartas25CSD
Message 1 of 9
i am trying to model a tapered polygonal tower in shell. When i do extrude with scale for a circle, it works perfectly, bet when i do that with 12 n polygon, it does it like that. How can i make this right?
Replies (8)
Message 2 of 9
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @simas.lembartas25CSD
I am not sure what method you are using for such tower definition bot maybe you could consider using library (parmetrised) structure to simulate such geometry
Krzysztof Wasik
Message 3 of 9
Thank you i will try. I am trying to model a polygonal monopile tower. So this way it is modeled as 12 nodes polygon and not a circle section, yes?
Message 4 of 9
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Yes library tower is based on parametrized polygons.
Krzysztof Wasik
Message 5 of 9
So to be sure, if i divide it to 12 nodes, i get a model for this:
Message 6 of 9
HI @simas.lembartas25CSD
Note that, in addition to what @Krzysztof_Wasik suggested, you can also create a faceted cone by specifying the number of edges (for example, 12), along with the height and the section dimensions.
https://help.autodesk.com/view/RSAPRO/2027/ENU/?guid=GUID-66D8C755-044F-4E08-9DAF-A3DE87B57247
You may also need to account for varying plate thicknesses, overlaps, and additional components such as manholes, branch connections, base plates, and cover plates. If you are working from a drawing, another option is to model the structure using simple plates based on a reference layout or a 3D wireframe imported from AutoCAD.
A finite element model can be very useful for validating and refining the design. However, in many cases, a parallel beam model can provide a much faster way to size the structure, with the finite element model then used to verify the final design.
Stephanekapetanovic_0-1786342971105.png Stephanekapetanovic_2-1785997999064.png
https://help.autodesk.com/view/RSAPRO/2027/ENU/?guid=GUID-EC5FD1DC-602A-4D1D-A1E6-2D41A750B1C9
Best Regards
Stéphane Kapetanovic
don't forget to click the Accept Solution button and leave a < like !
Message 7 of 9
Thank you for your insight. When i try to model it from panels, it does calculations for few hours, but if i do that with cone or the method suggested by Krzysztof_Wasik, it does calculations quickly.
Message 8 of 9
All these examples show that it is possible to access modeling functions in various ways and that modeling is easy.
Keep in mind that if your product is parametric, it is possible to automate modeling and calculations via the API. Many manufacturers are moving in this direction to automate their design processes once the procedures are established. Using shell elements instead of transformed objects provides greater flexibility for meshing and adding accessories.
' Creates a 3-segment tapered dodecagon mast (12-sided polygonal shell)
' Base diameter: 0.95m, Top diameter: 0.35m, Total height: 25m
Sub BuildTruncatedDodecagoneMast()
  Dim app As RobotApplication: Set app = New RobotApplication
  Dim o As RobotObjObjectServer: Set o = app.Project.structure.objects
  Const H = 25, db = 0.95, dt = 0.35, S = 3, E = 12, HS = H / S
  Dim pb As New RobotPointsArray, pt As New RobotPointsArray, pf As New RobotPointsArray
  pb.SetSize E: pt.SetSize E: pf.SetSize 4
  Dim tsl As RobotLabel, tsd As IRobotThicknessData, tsh As IRobotThicknessHomoData
  Dim labels As RobotLabelServer: Set labels = app.Project.structure.labels
  Dim MaxT%, tArr As Variant: tArr = Array(12, 10, 8): MaxT = UBound(tArr)
  For Each t In tArr
    Set tsl = labels.Create(IRobotLabelType.I_LT_PANEL_THICKNESS, ThkName(t))
    Set tsd = tsl.data: tsd.MaterialName = "Q345": tsd.ThicknessType = I_TT_HOMOGENEOUS
    Set tsh = tsd.data: tsh.ThickConst = (t - 0.04) / 1000
    labels.Store tsl
  Next t
  o.BeginMultiOperation
  Dim thk$, i%, j%, k%, n%, id%
  Dim hb#, ht#, Rb0#, Rt0#, dr#: Rb0 = db / 2: Rt0 = dt / 2: dr = (Rt0 - Rb0) / H
  For i = 0 To S - 1
    hb = i * HS: ht = hb + HS
    Fill pb, E, hb, Rb0 + dr * hb
    Fill pt, E, ht, Rb0 + dr * ht
    k = i: If i > MaxT Then k = MaxT
    thk = ThkName(tArr(k))
    For j = 1 To E
      If j = E Then n = 1 Else n = j + 1
      CopyPt pb, j, pf, 1: CopyPt pb, n, pf, 2: CopyPt pt, n, pf, 3: CopyPt pt, j, pf, 4
      id = o.FreeNumber: o.CreateContour id, pf
      With o.Get(id): .Main.Attribs.Meshed = 1: .SetLabel I_LT_PANEL_THICKNESS, thk: .Initialize: End With
    Next
  Next
  o.EndMultiOperation: app.Project.viewMngr.Refresh
End Sub
Function ThkName(t As Variant) As String
  ThkName = "THK_" & t & "_HDG"
End Function
Sub Fill(p As RobotPointsArray, n%, z#, r#)
  Dim a#: a = 6.28318530717959 / n: For i = 0 To n - 1: p.Set i + 1, r * Cos(i * a), r * Sin(i * a), z: Next
End Sub
Sub CopyPt(src As RobotPointsArray, i%, dst As RobotPointsArray, k%)
  Dim x#, y#, z#: src.Get i, x, y, z: dst.Set k, x, y, z
End Sub
Beyond modelling the shaft, the API can automate much more: connections, arm attachments, slip-joint overlaps, climatic loads (wind, seismic, ice), and code checks across several standards at once and behind a revamping project, there's often a code upgrade and ageing structure to account for too: GB, Eurocode, TIA-222, ASCE/SEI 48 + MOP 74, EN 50341. That makes it practical to compare standards or sweep many configurations in reasonable time.
On the innovation side, this can now connect to AI tools via an MCP server: an assistant can drive the model directly in natural language, generating geometry and running checks, while the engineer simply describes what to verify.
Programs can be written as a single block or, better, built in layers : more flexible, easier to maintain, and reusable across projects.
Best Regards
Message 9 of 9
bhavani_sankuratri
Hi @simas.lembartas25CSD ,
Hope you are doing good! I wanted to check whether the solution shared by Stephane.kapetanovic  helped with your polygonal tower model. If you are still having trouble, please let us know.
Bhavani Sankuratri | Community Manager
