Shear design
Shear design
MarekZiecina1253
Shear design
MarekZiecina1253
how to get interrupted basic control perimeter?
mustafahesenow
Hi @MarekZiecina1253
I think before you ask how to do design check for this point you need to be sure about the model you had created for this case
Is the column at the middle connected with wall and you assume it as linear support ?
Any way RSA understand only 3 locations for column (internal , Edge , and corner ) other than this you need to check it manually from shear stress maps
Mustafa Hesenow
Senior Structural Design Engineer/MZP
LinkedIn
Artur.Kosakowski
Autodesk Support
Autodesk Support
Could you attach this model?
Artur Kosakowski
MarekZiecina1253
Thank you for the reply. How checking manually from shear stress maps? Please give an example.
Artur.Kosakowski
Autodesk Support
Autodesk Support
I'm not sure why you need the support in the top node of the column but when it is defined it has to have its size defined as well Smiley Happy
Artur Kosakowski
MarekZiecina1253
can i check manually?
