Shear Calculation Notes for RC Column
The "calculation options" dialog (selected after entering the provided reinforcement for RC Column mode) allows for "shear considered" option. The help states that once this option is switched on the program check the shear force at both ends.
I noticed that the program selects stirrups diameter and spacing on graphical interface but there is no calculaton note. I would like very much to see the results of such calculation especially for high plasticity class columns which consider the plastic moment for shear.
Could you tell me if it is possible to see the notes for shear calculation?
Artur.Kosakowski
Autodesk Support
Autodesk Support
I'm sorry but this information is currently not displayed in the calculation note. The request has been added to the wish list.
Artur Kosakowski
Hi Arthur,
was this situation solved since 2012?
i'm having the same need at the moment.
Artur.Kosakowski
Autodesk Support
Autodesk Support
I'm sorry but this has not been done Smiley Sad
Artur Kosakowski
antonio.garciaJAFFP
Observer
Observer
Hi Arthur,
I am using RSA 2022 and facing the same problem. Was this wish solved?
Antonio
