Hello everyone. Hope youre all safe & healthy. I'm working on a two-storey RC residential building where Ive defined my loads and completed meshing. When running calculations, I get a separate structure warning which when highlighted, indicates all my nodes(including those defined within my meshes aka $SUB001$). I cant seem to identify any issues that would deem all the nodes as "Separate Structure"..Kindly assist
Solved by Simau. Go to Solution.
Hi @ambuchi67
Wall number 171 isn’t liked to the structure. Remove it if it doesn't paricipate to the stability, or link it
You have also type 1 instabilities. I removed releases on bars 108 109 137 114 122.
File attached
M. Agayr
