Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Select simple cases when printing tables
8 REPLIES 8
Message 1 of 9
Jelle.Visser
476 Views, 8 Replies
I'm trying to select only the simple cases before I print my reaction forces to csv.
However, reading through the documentation, I do find options to create cases, but I do not find a way to select a case for a table. I loop through the tables, and certain ones are "printed" to csv. However, now Reactions are all cases, I only want simple cases.
I tried to implement a solution given by @Stephane.kapetanovic
https://forums.autodesk.com/t5/robot-structural-analysis-forum/api-robot-vba-activate-or-select-load...
However, this does not seem to work. I would prefer to just the loadcase just for one table, because for the stresses and ratios I do want the combinations to be included.
                    Dim ViewMngr As IRobotViewMngr
                    Dim ActiveView As RobotView
                    Dim CaseSel As RobotSelection
                    Dim ActiveViewNumber As Long
                    ViewMngr = RobApp.Project.ViewMngr
                    For k = 1 To ViewMngr.ViewCount
                        If ViewMngr.GetView(k).Window.IsActive = -1 Then ActiveViewNumber = k : Exit For
                    Next k
                    ActiveView = ViewMngr.GetView(ActiveViewNumber)
                    CaseSel = ActiveView.Selection.Get(IRobotObjectType.I_OT_CASE)
                    CaseSel.FromText("Simple Cases")
                    ViewMngr.Refresh()
                    Console.WriteLine("Selected Simple Cases" & vbCrLf)
Now it crashes on line 10 (line 198 in the full script) with the message:
System.NullReferenceException
HResult=0x80004003
Message=Object reference not set to an instance of an object.
Source=RobotAPI
StackTrace:
at RobotAPI.Program.DumpTables() in C:\Users\Jelle.visser\source\repos\RobotAPI\RobotAPI\Program.vb:line 198
Labels (3)
8 REPLIES 8
Message 2 of 9
hi @Jelle.Visser
the context is not the same
you confuse the selection of preliminary load cases to a parametric view with that relating to tabulated results
Best Regards
Message 3 of 9
Ah yes, I assumed I was doing something wrong.
Can you point me in the right direction for selecting the active cases for tabulated results?
The documentation doesn't seem to have a clear solution, or at least I'm not seeing it.
Message 4 of 9
@Jelle.Visser
ok,
can you give me the full code?
The extract communicated concerns only the blocking point but it is not what you want.
Best Regards
Message 5 of 9
I can't paste the entire code here, that would be a bit long, but here is the repo:
https://github.com/Tebulo-Engineering/RobotAPI
The place where I tried to set the load case is line 189-201, and I print the reactions to csv on line 284 and onward
Message 6 of 9
hi @Jelle.Visser
each RobotTable has a function Select that can accept for first IRobotSelectionType and for second parameter a string that could contain load cases
Ex : MyTable.Select I_ST_CASE, "1 2 3 ... "
Best regards
Message 7 of 9
Now when I add the following line after the if statement to check if it's the reactions table, it doesn't output any reaction csv anymore at all.
tf.Select(IRobotSelectionType.I_ST_CASE, "1 2 3 4 5 6 7 8")
Do note that I am programming in VB.NET, seeing your code, I assume that's vbs/vba?
The first 8 cases are the simple cases, so that's what I'd want to select, but as long as it works, it shouldn't be hard to change it.
Message 8 of 9
hi @Jelle.Visser
tf refer to RobotTableFrame
Select method is part of IRobotTable interface
t is RobotTable and come from tf RobotTableFrame by method Get
Imports RobotOM.IRobotSelectionType '< at beginning
Dim t As RobotTable
Dim tf As RobotTableFrame
t = tf.Get(j)
t.Select(I_ST_CASE, "1to8") ' equivalent to IRobotSelectionType.I_ST_CASE
note that you can select bars by same method
t.Select(I_ST_BAR, "1 2 3 ...")
Best Regards
Message 9 of 9
Thank you, that works!
