Select simple bending with API
stathiseleftheriadis
Hi all,
Is there a way to select simple bending in the code parameters(attached) of a slab using API ?
Thanks.
Stathis
Rafal.Gaweda
Autodesk Support
Autodesk Support
As far as I can see it is not possible.
Create labels manually then use them by API
Rafal Gaweda
Thanks. That works.
