Seismic shear forces differences in ASCE7-10 ELFM and IBC 2009
Hi ,
I'm have started recently with some dynamic according ASCE7. I've spotted quite big a differnces in base shear using ELF comparing to modal  IBC.
Shoud the base shear be simmilar?
Model attached.
Frankundefined
Rafal.Gaweda
Autodesk Support
Autodesk Support
Results for my test model http://we.tl/RUsiPkZna0 :
undefined
Rafal Gaweda
Thank you Rafal,
Looks the shear is the same for both cases for dynamic and static ELF method as we define the perionds manually for each direction X and Y.
However, there are still some discrepancies, which are not clear to me. I have ammended the model you have attached this morning by removing the user defined perion in dynamic and ELF static method.
The summ of reaction for ELF is much bigger than for Dynamic. Not sure why. Some other questions (screenshoot).
Thanks and Regards,
Frank
undefined
Rafal.Gaweda
Autodesk Support
Autodesk Support
It seems change of S1 parameter is the cause.
It must be deeper checked by developers.
Thank You for reporting
Rafal Gaweda
Rafal.Gaweda
Autodesk Support
Autodesk Support
Frank,
As far as we checked period T is calculated as T <= Cu * Ta, according to 12.9.4
Could you please check, verify, clarify if our assumptions are wrong?
Etabs does it in the same way : point 2.9.1 here http://www.ottegroup.com/manuals/ETABSLateral%20Loads%20Manual.pdf
Rafal Gaweda
Rafal,
Looks that assupmtions are correct. It is not only "Precise(modal analysis)" but combination of modal and empirical one and its comparation. What I'm missing  is the imput paramenter Ct as RSA is taking Ct=0.02 (0.0488) as default (Table 12.8-2 of ASCE), in which some cases it might be too conservative. ETABS seems have this option as stated in 2.9.1 (Program calculated).
Frank
Rafal.Gaweda
Autodesk Support
Autodesk Support
OK, registered on wishlist.
Thx
Rafal Gaweda
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
