Seismic Dispositions : No Requirements!
JJSchembri
JJSchembri
when I am designing reinforced concrete columns in a particular file, I am getting the following error-  Seismic Dispositions : No Requirements!
Can someone help please?
Justin
Artur.Kosakowski
Autodesk Support
Autodesk Support
Try to select other than "non" or mark the corresponding check box depending on the code you selected.
Artur Kosakowski
JJSchembri
Many thanks for your feedback.
I tried it however now  I am getting the following error: Column21 - No synchronisation with the structure.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Try to design the adjoining beams first.
Artur Kosakowski
