Seismic Base shear displayed in both X and Y direction for load type EQY
bhuvnesh.kapoor2558AS
I have defined seismic load type for my analysis model in X and Y direction. When I check base reaction I see reaction in both X and Y direction for EQY, however for EQX it is showing correctly.
Can anyone please tell what is the cause for this issue ?
Simau
hi @bhuvnesh.kapoor2558AS
Could you share your model.
Zip it before attaching
M. Agayr
File attached.
Simau
In your modale analysis, mode 1 is a torsion mode so it will create  forces in X and Y
You must increase Kx and Ky or block the raft contour in X and Y direction
M. Agayr
Restraining the raft in X and Y direction did the job. Thanks Simau!
