I think I need a bit of explanation for the seismic analysis principals in Robot.
OK, what’s the issue:
2D Steel frame. Very simple.
Firtstly I run modal analysis. Got whay I have expected.
Than I go for Seismic case with Newmark comb CQC (+ proper combination sign).
Now I read results ie. bending moments for each CQC combination.
Should I get results of moments from earthquake acting in +X direction and acting in -X direction? Results from cqc combination looks like earthquake acted only in one direction – towards X+.
Basically, based on modal shapes structure was deforming (sway deformation) the same to the right +X and the same to the left -X. So my understanding is seismic should act in a similar way, giving utilization once in X+ and X- dir
I do not know if my understanding of a problem is right…. What you think of it?
Solved by Simau. Go to Solution.
Solved by Krzysztof_Wasik. Go to Solution.
Hi @micp_rsa
Opposite seismic action direction should be considered by seismic combination definition. It can be done manualy (+ and - sign defined in manual combination including seismic cases), or it can be done automatically in Automatic combination module when Seismic Accidental combinations are chosen. Then combination module uses + and - for seismic cases in generated seismic combinations.
Thank you @Krzysztof_Wasik
I should have gone one step ahead to see that RSA cobines load with "+" and "-" sign automatically. Thought I need to have all simple cases as for example like wind.
One more question. I want to prepare automatic combinations.
I turned off case 4 and 5 to get involved only seismic cases 6to9. Is is the right approach?
Still have 4 and 5 in com list...
thanks @Simau and @Krzysztof_Wasik
So basically I will not see cases 6to9 in the definition of Seismic automatic combination table, despite I have them checkboxed in automatic combination defnition as a cases?
They will allway be represented by simple cases 4 and 5. Is it right? Please see screen below.
When we perform a spectral analysis Robot has the possibility of specify the acidental eccentricity. In a seismic analysis, in some codes too. But on other codes like NP EN 1998-1:2013 (Portugal EC8) Robot simply doesn't have that option. Do you have any idea why and how to solve it?
Thanks!
