seismic analysis low values
I have defined the seismic analysis as per the webinars but it gives too low values. Can someone have a look to the model please? thanks
sorted. I think it was a bug. If I define a modal analysis, then a buckling and then the seismic, the latter takes the eigenvalues from the buckling instead than from the modal.
was it a known problem?
Artur.Kosakowski
Autodesk Support
Autodesk Support
Personally I haven't been aware of this. Thank you for notifying us about this situation.
Artur Kosakowski
