Sectoral moment of inertia
andrei_costanJ33N8
Message 1 of 8
andrei_costanJ33N8
Where can l find in Autodesk Robot the value for sectoral moment of inertia (Iw-cm^6) for a section that I have defined?
Thank you,
have a nice day
Replies (7)
Message 2 of 8
Stephane.kapetanovic
hi @andrei_costanJ33N8
look at these topics
Sectorial moment of inertia (I omega) in Section Builder and Steel design module
Custom Section Properties - torsional/warping constant
Best Regards
Stéphane Kapetanovic
don't forget to accept the solution and leave a < like !
Message 3 of 8
CaioSaporito
Hi @andrei_costanJ33N8 .
Where did you define this section? Section definition or parametric section?
Best regards,
Caio
Message 4 of 8
andrei_costanJ33N8
Good morning
In <define section> - <thin walls>
Message 5 of 8
CaioSaporito
Hi @andrei_costanJ33N8.
Have you seen this?
Best regards,
Caio
Message 6 of 8
andrei_costanJ33N8
I have an I section, and results are not corect (A, Ix, Iy, Iz, Iom) - my point of view.
Message 7 of 8
could you briefly give the dimensions of the section, possibly share the model, say which value is false (value estimated by you).
Best Regards
Message 8 of 8
CaioSaporito
If you are in "thin walled" mode, you necesseraly have to draw your section only with line and then you modify the thickness.
Select all the line / right click / propeties / thickness
Best regards,
Caio
