Section Shape Type - Can't find the right number
Hi guys
I'm quite new into generating my own sections in robot and face a challenge in defining the "Section Shape Type".
So what i have done at this moment is to insert two standard profiles (a UPE200 & a IPE200). One on top of the other.
Did the standardization and calculation which seems right since i'm able to get the section analysis.
However i can't seem to figure out which "section Shape Type" i need to define for the section.
Found this link: http://help.autodesk.com/view/RSAPRO/2015/ENU/?guid=GUID-37C90ACA-0068-46B0-9CE2-76DEF8EED292
Went into the Section database to define the Section shape: And lodaded the User database where the section was saved (using the ? in section shape type).
Can anyone point me in the right direction of choosing a proper "section shape Type" for the above section?
BR Nikolai
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi Nikolai,
Let me ask you a following question - what code formulas (for which profile type) would you use to manually check this section?
Artur Kosakowski
Hi
I would use EN 1993-1-1 Design of Steel Structures.
Tried to determine the cross section class:
Web: Class 3
(Upper) Flange: Class 1
Found a note in EC3 section 6.2.2.4 which tells that if the web is class 3 and the flange is 1 or 2 then the cross section class is allowed to be set as: 2.
Is this the answer you were looking for?
BR Nikolai
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
What you name a web and the flange? Are they to be considered as a web and flange of I beam or a channel?
Artur Kosakowski
Hi
For an I beam is how i did the calc.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
So in the same way  you should select the I shape symbol saving this section to the user database.
Artur Kosakowski
