Section Modulus/Second Moment Area of Wall
No aplicable
492 Vistas
2 Respuestas
Mensaje 1 de 3
No aplicable
Is there a way to calculate the section modulus or second moment area of walls in robot? I've tried grouping them into 'core walls' and checking the results tables for core walls and storeys but can't find the correct information.
0 Me gusta
Soluciones aceptadas (1)
493 Vistas
2 Respuestas
Respuestas (2)
Mensaje 2 de 3
Artur.Kosakowski
Autodesk Support
Autodesk Support
Solución aceptada
Hi @Anonymous
You may want to consider defining the sections of the corresponding shapes in the Section Builder module of Robot and then calculate their properties to determine the values you are looking for.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
0 Me gusta
Mensaje 3 de 3
No aplicable
Hi
I was hoping that wasn't the answer. It takes a while to model a large core in the section editor and then to change the thicknesses of walls if the value returned is too small.
0 Me gusta
