Section Definition
Section Definition
TSOFA
Section Definition
TSOFA
Hi all,
I have to reinforce a steel roof structure and I will weld 2UPN50 to a tubular 60X40X2. The strange thing is that when I will have to catigorize the section (see pic), the results get different when I pick the first or the second choise. The problem is that this kind of section doesn't belong to one of the available categories of software
Rafacascudo
The category type is only important if you want to design it.
Main Section properties ,A , J , should be the same on both categories.
Rafael Medeiros
TSOFA
But the whole scope is to design it.
Nicolas.Ratel
You have to classify this section by yourself, there is not typical design for it.
If you want to be conservative, take "u".
After that you use §6.3 EC3-1-1 to check instabilities.
Best regards,
NR.
TSOFA
ok, so this is something that the designer should deside, eventhough I thing is a little "dangerous". Is there a module to calculate §6.3 EC3-1-1 ?
Nicolas.Ratel
No for me it's always safety to check the design by hand calculation, and compare if you are ok with the software.
Of course RSA do that  :
Best regards,
NR.
