Section definition - weighted properties formula
Hello everyone,
I don't understand how the weighted properties of a composite material are calculated in the section définition tool. The help (https://help.autodesk.com/view/RSAPRO/2019/ENU/?guid=GUID-3C08787E-34CE-4FB0-B0B0-DFDC50EA9E8E ) gives the following formula for a weighted property A* :
What is "a" (or "alpha" ?) ?
Plus, I have two materials side to side, and not a fiber reinforced material for example. Is it OK to use the properties given by the section definition tool, assuming the larger material as the "base" ?
(This second question may be answered with the first one)
Best regards,
François
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @Anonymous
"Alpha-i" are section/contour material property. For most coefficients(Ax, Iy, Iz) Young modulus is used.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Krzysztof Wasik
