Screen capture size
Screen capture size
vuk.vukanic
Message 1 of 10
Screen capture size
vuk.vukanic
I'm having trouble with the size of screen catures.
Randomly it changes when I print to .pdf (as illustrated in the attachments).
Can someone point me in the right direction when it come to this tool. The settings I used with SC that gave the results are attached.
Easy things are not worth the effort
http://www.teamcad.rs
Replies (9)
Message 2 of 10
Rafal.Gaweda
Autodesk Support
Autodesk Support
Message 3 of 10
vuk.vukanic
That procedure deleted my printout composition, actually it is still there, but only prints the first 2 pages.
It wont be a big deal to redo it, but would rather avoid it if possible.
Alsow is there a way of showing the section shapes in the printout? I only manage to get names and the properties in tables format.
Thank you
Message 4 of 10
Rafal.Gaweda
Autodesk Support
Autodesk Support
Rafal Gaweda
Message 5 of 10
Rafal.Gaweda
Autodesk Support
Autodesk Support
Rafal Gaweda
Message 6 of 10
vuk.vukanic
Ah... Sorry for the confusion.
I'll try to illustrate the issue.
After opening the file in repair mode, saving, running the calculations, and printing, the already set up printout composition (before the repair) result is the attached pdf.
Is there a way to recover the printout setup or do I have to redo it?
The other thing regarding the section shapes is alsow in the print, and not the display options.
I have managed to get the section shape to appear only when printing simplified report within the properties.
I would like to have that section shape displayed in the printout (not the simplified one). Is this possible and how?
Most helpful would be any kind of instructions regarding setup of the printout, since this is the area that is causing me most of the issues at the moment.
I would like to point out that I'm having problems with my graphics card, and ask could it be the reason for the issues above?
Thank you for you time and help
Message 7 of 10
Rafal.Gaweda
Autodesk Support
Autodesk Support
Resize it this way:
Rafal Gaweda
Message 8 of 10
vuk.vukanic
Perfect, that's what I was looking for, and forgive me, but I have to ask:
How on earth did you Screen Capture the properties of the section? What window was open?
Message 9 of 10
Rafal.Gaweda
Autodesk Support
Autodesk Support
Rafal Gaweda
Message 10 of 10
vuk.vukanic
Thank you so much.
You have been great.
Smiley Happy
